Fastfetch, add os age
Hi, here’s my Fastfetch configuration jsonc file:
  "$schema": "https://github.com/fastfetch-cli/fastfetch/raw/dev/doc/json_schema.json",
  "modules": [
    "title",
    "separator",
    "os",
    "kernel",
    "shell",
    "locale",
    "break",
    "colors"
  "logo": "cachyos_small"
How can I add os age here?
I took this out of my config.jsonc which is part of the ChrisTitusTech’s .bashrc Configuration I use:
“type”: “command”,
“key”: " OS Age ",
“keyColor”: “magenta”,
“text”: “birth_install=$(stat -c %W /); current=$(date +%s); time_progression=$((current - birth_install)); days_difference=$((time_progression / 86400)); echo $days_difference days”
On my system it shows a nice:
OS Age → 5 days
Hope it is of some use to you
