I’ve linux-cathyos 6.11 from Aur compiled and installed on EndeavourOS,
but when boot it says start job is working for the uuid 71709de4-7436-4a88-9801-f8e98d0d4b18, and after 10 minutes it wont finish. It will stuck on this start job every time.
So somehting is needed for it to boot I guess.
Here’s my fstab, works with stock kernel and linux-clear
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B223-12CA /boot/efi vfat fmask=0137,dmask=0027 0 2
UUID=71709de4-7436-4a88-9801-f8e98d0d4b18 / btrfs subvol=/@,noatime,compress=zstd 0 0
UUID=71709de4-7436-4a88-9801-f8e98d0d4b18 /home btrfs subvol=/@home,noatime,compress=zstd 0 0
UUID=71709de4-7436-4a88-9801-f8e98d0d4b18 /var/cache btrfs subvol=/@cache,noatime,compress=zstd 0 0
UUID=71709de4-7436-4a88-9801-f8e98d0d4b18 /var/log btrfs subvol=/@log,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
also
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
└─sda2 ntfs Seagate Expansion Drive 4EC2A881C2A86EC1
nvme1n1
└─nvme1n1p1 ntfs IntelNVME 0C24FA6324FA4EE8
nvme0n1
├─nvme0n1p1 vfat FAT32 B223-12CA 67.2M 35% /boot/efi
├─nvme0n1p2
├─nvme0n1p3 ntfs E84294AE429482CC
├─nvme0n1p4 ntfs 5C10BCCA10BCAC80
└─nvme0n1p5 btrfs endeavouros 71709de4-7436-4a88-9801-f8e98d0d4b18 14.7G 70% /var/log
/var/cache
/home
grub:
# GRUB boot loader configuration
#GRUB_DEFAULT='0'
GRUB_DEFAULT=0
GRUB_TIMEOUT='5'
GRUB_DISTRIBUTOR='EndeavourOS'
GRUB_CMDLINE_LINUX_DEFAULT='nowatchdog nvme_load=YES loglevel=3'
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY='true'
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_BACKGROUND='/usr/share/endeavouros/splash.png'
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU='false'
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER=false
GRUB_EARLY_INITRD_LINUX_STOCK=''
