Display settings not saving (After logout and log in.)
Just installed CachyOS to give it a try. And everything is working in steam and lutris just fine. But when I change the display settings in the desktop it saves fine. I log out then log back in or restart and it goes back to default.
Change I made
165 for refresh
HDR enabled
125% increase in desktop size (its a little to small by default)
CPU:5900x
GPU: 4070
RAM: 32GB DDR4
That is sadly a plasma issue. Should be hopefully fixed with 6.1.
So I changed to x11 and it seems to work, and save.
