Depency issue is blocking my updates - SOLVED
yay :
15 paquets à mettre à jour ou à installer.
15 cachyos-v3/lib32-nvidia-utils 565.57.01-1 → 565.77-1
14 cachyos-v3/lib32-opencl-nvidia 565.57.01-1 → 565.77-1
13 cachyos-v3/linux-cachyos 6.12.1-2 → 6.12.2-2
12 cachyos-v3/linux-cachyos-headers 6.12.1-2 → 6.12.2-2
11 cachyos-v3/linux-cachyos-nvidia 6.12.1-2 → 6.12.2-2
10 cachyos-v3/nvidia-utils 565.57.01-3 → 565.77-2
9 cachyos-v3/opencl-nvidia 565.57.01-3 → 565.77-2
8 cachyos-extra-v3/cmake 3.31.1-1.1 → 3.31.2-1.1
7 cachyos-extra-v3/python-fonttools 4.55.1-1.1 → 4.55.2-1.1
6 cachyos/brave-bin 1:1.73.91-1 → 1:1.73.97-1
5 cachyos/cachyos-snapper-support 1.0.1-1 → 1.0.1-2
4 cachyos/hypnotix 4.6-1 → 4.7-1
3 core/hwdata 0.389-1 → 0.390-1
2 extra/perl-image-exiftool 13.05-1 → 13.06-1
1 extra/sof-firmware 2024.09.1-1 → 2024.09.2-1
résolution des dépendances…
recherche des conflits entre paquets…
erreur : la préparation de la transaction a échoué (la satisfaction des dépendances a échoué)
:: l’installation de nvidia-utils (565.77-2) casse la dépendance « nvidia-utils=565.57.01 » requise par linux-cachyos-sched-ext-lto-nvidia
in english :
the error is saying that the installation of nvidia-utils (565.77-2) is breaking nvidia-utils=565.57.01 requiered by linux-cachyos-sched-ext-lto-nvidia
6.11.8-1-cachyos-sched-ext-lto
is my kernel.
Probably because the kernel ...-sched-ext-lto is more or less now unmaintained, happened to be with the autofdo kernel.
thankyou guys . i did not knew about that.
i cant remove it from the gui (cahyos kernel manager) since it is not display on the app anymore.
I would like to install a new one but i dont know wich one to pick.
i mainly do video games and very basic web/multimedia on an old computer.
i’ve read the autofdo blog post but it said it works with every cpu after haswell and i have an xeon-e3 (haswell). is it haswell included ?
if not v3-bore-lto maybe ?
i still have the “basic” v3 one installed tho.
if you have some commands/ wiki links to do so i’ll be happy :slight_smile:
Edit : ive just understood your message about autofdo
ive tried to install v3-bore-lto trough the graphical kernel manager and it prompt me the same error.
So i rlly need to know how to delete and switch back to the normal kernel trough cmdlines or maybe at the grub , i dont know .
Just install the default one and once booted into that one you can remove the old with
sudo pacman -Rns
thank you , it worked perfectly !
