Chromium installation does not find a mirror
Hey CachyOS community,
I’m pretty new to this OS.
I want to install chromium, but manually executing the installation command as well as trying to install it from the Cachy package installer fails, because every mirror returns 404:
What would be the issue here and how to work around that issue?
Thanks for your help!
PS: It seems to be the case with everything I currently try to install.
then update mirrors
sudo cachyos-rate-mirrors
Thanks for your quick help. Unfortunately that did not fix the issue for me.
Interesting…
I have updated all packages and rebooted, now it works again :+1:
