how can a one changing the System Language after! installing the CachyOS to another as choosed during install ?
depends on the used DE
pls xplain a bit more details to understand what u mean
Which Desktop Enviroment you did install? KDE?
can do it by editing /etc/locale.conf
if you prefer the gui-way, it depends on what DE it is
on plasma e.g. open the mainmenu, chose âRegion&Languageâ and change âLanguageâ
xfce need french lang, câest possible ?
ty, merci
merci !
First look in " nano /etc/locale.gen" find your perfered language as root set it, and run âlocale-genâ also as root.
1st
sudo nano /etc/locale.gen
select your choice then save and exit.
now run
sudo locale-gen
It wouldnât hurt to verify with
locale
you may run as root â tu pourrais faire ce qui suit
localectl set-locale LANG=fr_FR.UTF-8
Merci. Did so. Result is this:
Franck: localectl status
System Locale: LANG=fr_FR.UTF-8 UTF-8
LC_TIME=fr_FR.UTF-8 UTF-8
LC_TELEPHONE=fr_FR.UTF-8 UTF-8
VC Keymap: fr
X11 Layout: fr
nothing changed, xfce is still english
Merci. Did so and with localectl too. Result is this:
VC Keymap: fr
X11 Layout: fr
did you reboot ?
@hotte i have the same results the OP has and was fixed with:
unset LANG
And:
source /etc/profile.d/locale.sh
So before it looked like:
locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
Now after the two commands:
locale
LANG=fr_FR.UTF-8
LC_CTYPE="fr_FR.UTF-8"
LC_NUMERIC="fr_FR.UTF-8"
LC_TIME="fr_FR.UTF-8"
LC_COLLATE="fr_FR.UTF-8"
LC_MONETARY="fr_FR.UTF-8"
LC_MESSAGES="fr_FR.UTF-8"
LC_PAPER="fr_FR.UTF-8"
LC_NAME="fr_FR.UTF-8"
LC_ADDRESS="fr_FR.UTF-8"
LC_TELEPHONE="fr_FR.UTF-8"
LC_MEASUREMENT="fr_FR.UTF-8"
LC_IDENTIFICATION="fr_FR.UTF-8"
LC_ALL=
never used that script
but itâs fine as it brings the solution
