I bet I’d have to switch the kernel and reinstall and rebuild everything using the new repos but I have no idea how to start doing that or if it’s even possible. I don’t really want to reinstall and loose everything currently.
Thank you for your help!
Edit the v3 counterparts to the above and reinstall all packages from CachyOS Hello.
Thanks Naim!
Worked perfectly, I reinstalled everything using:
sudo pacman -Sy yes | sudo pacman -Scc sudo pacman -Syu sudo pacman -Qqn | sudo pacman -S -
