I just installed CachyOS with KDE Plasma and enabled Bluetooth in CachyOS Hello, it sees the device but when i try to connect it just loads for a few minutes and then brings up an error.
There may be some discrepancies with bluetooth in the latest kernel at the moment. Can you check if bluetooth works fine with the lts kernel? sudo pacman -S linux-cachyos-lts linux-cachyos-lts-headers
Still doesn’t work
Can you send a log? sudo cachyos-bugreport.sh
Suggestion from another forum (by tbg)
If the [LTS] doesn’t help, try replacing bluedevil with an alternative power manager like TLP:
Same issue with my Pixel Buds 2 Pros. On KDE cannot connect/pair them through the GUI.
But you can use bluetoothctl through the terminal and I got my buds paired through that
I tried that too, gives me a bluez timeout error.
