Can local newer than cachyos warnings be ignored when running a system update
When running system update, I’m getting this warning:
warning: expat: local (2.6.4-1) is newer than cachyos-core-znver4 (2.6.3-2.1)
there is nothing to do
Am I correct in assuming that it’s because the package was updated on 2024-11-08 11:19 UTC and that that cachyos update should follow at some point?
Thanks!
Edit: found this: Warning wine version . I guess that answers my question.
Yes you can just ignore them. Means just that Arch has updated its package and the package in cachy repos isn’t yet synced/built.
Safely ignore it. In general pacman will install the cachyos version instead of arch official repo even if it’s newer. But this expat is a dependency that lib32-expat requires the same version. But cachyos’ repo does not maintain this package. So as you update the lib32 package, the expat update to the official version too.
