No, just run the command.
Thank you, but COSMIC can’t run.
You should atleast try to give some info why it doesn’t run, what happens etc if you want someone to actually try to help you.
cosmic far from ready to daily drive anyway… It installs and runs “just fine” when i install it using the commands above. I then swiftly remove it again…
It depends on your pickiness. I’ve worked in it for hours and had no problems. Admittedly not every feature exists, but it usually does seem to work fine for basic usage.
I wanted to see not long ago how lates Cosmic alpha is shaping up, so I installed it again. I couldn’t use it with my normal user as it froze with a gray background and a rectangle in top-left corner.
So I just created a separate user, and with that I can use Cosmic without issues.
So for Cosmic needs pray and waiting for
Lead dev of cosmic says memory usage is entirely dependent on the number of fonts installed. They didnt fix this yet. Thats just one silly bug, you may or may not experience…A properly functional kde plasma dynamic tiling plugin would be a better use of time than rewriting a whole DE from scratch, but hey its not my choice! Cosmic reminds me of unity in a weird way and i dont like that fact haha…
