Cachyos-testing-v3 repository permission issue?
tried to ru an -Syu update and kept on having problems reading the db file:
Blockquote
debug: checking signature for /var/lib/pacman/sync/cachyos-testing-v3.db
debug: 1 signatures returned
debug: fingerprint: 882DCFE48E2051D48E2562ABF3B607488DB35A47
debug: summary: valid
debug: summary: green
debug: status: Success
debug: timestamp: 1738572885
debug: exp_timestamp: 0
debug: validity: full; reason: Success
debug: key: 882DCFE48E2051D48E2562ABF3B607488DB35A47, CachyOS admin@cachyos.org, owner_trust marginal, disabled 0
debug: signature is valid
debug: signature is fully trusted
debug: setting usage of 15 for cachyos-testing-v3 repository
debug: adding new server URL to database ‘cachyos-testing-v3’: Nginx Directory
debug: adding new server URL to database ‘cachyos-testing-v3’: https://hun.cachyos.org/repo/x86_64_v3/cachyos-testing-v3
debug: adding new server URL to database ‘cachyos-testing-v3’: https://sg.cachyos.org/repo/x86_64_v3/cachyos-testing-v3
debug: adding new server URL to database ‘cachyos-testing-v3’: https://kr.cachyos.org/repo/x86_64_v3/cachyos-testing-v3
debug: adding new server URL to database ‘cachyos-testing-v3’: us.cachyos.org
debug: adding new server URL to database ‘cachyos-testing-v3’: cachyos-testing-v3
debug: adding new server URL to database ‘cachyos-testing-v3’: Index of /cachy/repo/x86_64_v3/cachyos-testing-v3/
debug: option ‘sandboxuser’ = (null)
Root : /
Conf File : /etc/pacman.conf
DB Path : /var/lib/pacman/
Cache Dirs: /var/local/pacman/pkg/
Hook Dirs : /usr/share/libalpm/hooks/ /etc/pacman.d/hooks/
Lock File : /var/lib/pacman/db.lck
Log File : /var/log/pacman.log
GPG Dir : /etc/pacman.d/gnupg/
Targets : None
:: Synchronizing package databases…
cachyos-testing-v3 downloading…
debug: cachyos-testing-v3.db: url is https://mirror.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
debug: cachyos-testing-v3.db: maxsize 134217728
debug: cachyos-testing-v3.db: using time condition 1738612147
debug: cachyos-testing-v3.db: opened tempfile for download: /var/lib/pacman/sync/download-zWkK9S/cachyos-testing-v3.db.part (wb)
debug: cachyos-testing-v3.db: curl returned result 0 from transfer
debug: cachyos-testing-v3.db: response code 404
error: failed retrieving file ‘cachyos-testing-v3.db’ from sg.cachyos.org : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://kr.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
debug: cachyos-testing-v3.db: curl returned result 6 from transfer
error: failed retrieving file ‘cachyos-testing-v3.db’ from kr.cachyos.org : Could not resolve host: kr.cachyos.org
warning: fatal error from kr.cachyos.org, skipping for the remainder of this transaction
debug: cachyos-testing-v3.db: retrying from https://us.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from us.cachyos.org : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://mirror.albony.xyz/cachylinux/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from mirror.albony.xyz : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://mirror.lesviallon.fr/cachy/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from mirror.lesviallon.fr : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://mirror.truenetwork.ru/cachy/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from mirror.truenetwork.ru : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://mirror.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from mirror.cachyos.org : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://aur.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
error: failed retrieving file ‘cachyos-testing-v3.db’ from aur.cachyos.org : The requested URL returned error: 404
debug: cachyos-testing-v3.db: retrying from https://sg.cachyos.org/repo/x86_64_v3/cachyos-testing-v3/cachyos-testing-v3.db
debug: cachyos-testing-v3.db: no more servers to retry
debug: curl_download_internal return code is -1
debug: failed to sync dbs: failed to retrieve some files
error: failed to synchronize all databases (failed to retrieve some files)
debug: unregistering database ‘local’
debug: unregistering database ‘cachyos-testing-v3’
But when i tried to manually get the file, by hiting it with the browser, it seems to work fine. Am I missing something ?
Oh, sorry. Didnt expect that people use the testing repository.
Issue has been fixed now.
