CachyOS scx-sheduler is fantastic!
CachyOS scx-scheduler smooths my desktop experience and appears to use the CPU cores efficiently, keeping the temperatures down.
           .-------------------------:                    indy@cachyos-x8664
         :++===++==================-       :++-           OS: CachyOS Linux x86_64
        :*++====+++++=============-        .==:           Kernel: Linux 6.10.9-2-cachyos
       -*+++=====+***++==========:                        Uptime: 1 hour, 23 mins
      =*++++========------------:                         Packages: 991 (pacman)
     =*+++++=====-                     ...                Shell: fish 3.7.1
   .+*+++++=-===:                    .=+++=:              Display (49M2C8900L): 5120x1440 @ 144 Hz in 49″ [External]
  :++++=====-==:                     -*****+              DE: GNOME 46.4
 :++========-=.                      .=+**+.              WM: Mutter (Wayland)
.+==========-.                          .                 WM Theme: Adwaita
 :+++++++====-                                .--==-.     Theme: Adwaita [GTK2/3/4]
  :++==========.                             :+++++++:    Icons: Adwaita [GTK2/3/4]
   .-===========.                            =*****+*+    Font: Cantarell (11pt) [GTK2/3/4]
    .-===========:                           .+*****+:    Cursor: Adwaita (24px)
      -=======++++:::::::::::::::::::::::::-:  .---:      Terminal: GNOME Terminal 3.52.2
       :======++++====+++******************=.             Terminal Font: Source Code Pro (10pt)
        :=====+++==========++++++++++++++*-               CPU: 13th Gen Intel(R) Core(TM) i9-13900K (24) @ 6.00 GHz
         .====++==============++++++++++*-                GPU: NVIDIA GeForce RTX 4090 [Discrete]
          .===+==================+++++++:                 Memory: 4.71 GiB / 94.14 GiB (5%)
           .-=======================+++:                  Swap: 0 B / 94.14 GiB (0%)
             ..........................                   Disk (/): 73.31 GiB / 1.79 TiB (4%) - ext4
                                                          Local IP (eno2): 192.168.178.24/24
                                                          Locale: en_GB.UTF-8
❯ systemctl status scx
● scx.service - Start scx_scheduler
     Loaded: loaded (/usr/lib/systemd/system/scx.service; enabled; preset: disabled)
     Active: active (running) since Fri 2024-09-13 11:59:03 BST; 1h 23min ago
 Invocation: 5407255c5991487ead0226a7f4b41f8b
   Main PID: 909 (scx_lavd)
      Tasks: 4 (limit: 115526)
     Memory: 29.9M (peak: 31.2M)
        CPU: 751ms
     CGroup: /system.slice/scx.service
             └─909 scx_lavd --autopower
Sep 13 11:59:03 cachyos-x8664 systemd[1]: Started Start scx_scheduler.
Sep 13 11:59:03 cachyos-x8664 bash[909]: 10:59:03 [INFO] scx_lavd scheduler is initialized (build ID: 1.0.4-gfb35fdb-dirty x86_64-unknown-l>
Sep 13 11:59:03 cachyos-x8664 bash[909]: 10:59:03 [INFO] scx_lavd scheduler starts running.
Sep 13 11:59:03 cachyos-x8664 bash[909]: 10:59:03 [INFO] Set the scheduler's power profile to balanced mode.
Sep 13 11:59:06 cachyos-x8664 bash[909]: 10:59:06 [INFO] Set the scheduler's power profile to performance mode.
Of course ! lol
Hey @altman, regarding your previous question about my RAM, I have two 48GB sticks of Corsair Vengence DDR5 6400.
❯ sudo dmidecode --type 17
# dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 3.5.0 present.
Handle 0x000D, DMI type 17, 92 bytes
Memory Device
	Array Handle: 0x000C
	Error Information Handle: Not Provided
	Total Width: 64 bits
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: Controller0-DIMM0
	Bank Locator: BANK 0
	Type: DDR5
	Type Detail: Synchronous
	Speed: 6400 MT/s
	Manufacturer: Corsair
	Serial Number: 00000000
	Asset Tag: 9876543210
	Part Number: CMK96GX5M2B6400C32
	Rank: 2
	Configured Memory Speed: 6400 MT/s
	Minimum Voltage: 1.1 V
	Maximum Voltage: 1.4 V
	Configured Voltage: 1.1 V
	Memory Technology: DRAM
	Memory Operating Mode Capability: Volatile memory
	Firmware Version: Not Specified
	Module Manufacturer ID: Bank 3, Hex 0x9E
	Module Product ID: Unknown
	Memory Subsystem Controller Manufacturer ID: Unknown
	Memory Subsystem Controller Product ID: Unknown
	Non-Volatile Size: None
	Volatile Size: 48 GB
	Cache Size: None
	Logical Size: None
Handle 0x000E, DMI type 17, 92 bytes
Memory Device
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: Controller1-DIMM0
	Type: DDR5
	Speed: 6400 MT/s
	Rank: 2
	Cache Size: None
	Logical Size: None
Wow, my dream RAM @indy
Are those the Titanium series @indy
No, just the standard.
Hey cool, that must be a monster !
Here are my crap-RAMs ! lol X2 for a little while till I have the other parts in order to make another install;
# dmidecode 3.6
SMBIOS 3.1.1 present.
Handle 0x0011, DMI type 17, 40 bytes
Memory Device
	Array Handle: 0x0010
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: ChannelA-DIMM0
	Type: DDR4
	Speed: 2667 MT/s
	Manufacturer: Kingston
	Serial Number: B550ECB1
	Part Number: 9905713-030.A00G
	Rank: 1
	Configured Memory Speed: 2667 MT/s
	Minimum Voltage: Unknown
	Maximum Voltage: Unknown
	Configured Voltage: 1.2 V
The kernel I use already has the scheduler on it,
❯ uname -a
Linux cachyos-x8664 6.10.9-1-cachyos-sched-ext-lto #1 SMP PREEMPT_DYNAMIC Sun, 08 Sep 2024 19:52:25 +0000 x86_64 GNU/Linux
Ha! Slightly newer on mine.
❯ uname -a
Linux cachyos-x8664 6.10.9-2-cachyos #1 SMP PREEMPT_DYNAMIC Sun, 08 Sep 2024 18:17:48 +0000 x86_64 GNU/Linux
I also followed the instructions here,
and edited the /etc/default/scx and then executed sudo systemctl enable --now scx. My /etc/default/scx looks like:
# List of scx_schedulers: scx_bpfland scx_central scx_lavd scx_layered scx_nest scx_qmap scx_rlfifo scx_rustland scx_rusty scx_simple scx_u>
SCX_SCHEDULER=scx_lavd
# Set custom flags for each scheduler, below is an example of how to use
SCX_FLAGS='--autopower'
I found the scx-lavd --autopower is the best out of all.
Oh, cool ! Thx for the link, looked at it a while ago & found that too complicated for me ! lol
Here s mine results @indy , defaults from the kernel; Edit: I didn t know of those results beforehand;
# List of scx_schedulers: scx_bpfland scx_central scx_lavd scx_layered scx_nest scx_qmap scx_rlfifo scx_rustland scx_rusty scx_simple scx_userla>
SCX_SCHEDULER=scx_bpfland
#SCX_FLAGS='-s 20000 --lowlatency --primary-domain all'
Run systemctl status scx and see the output. I get:
     Active: active (running) since Fri 2024-09-13 11:59:03 BST; 3h 17min ago
     Memory: 30.1M (peak: 31.2M)
        CPU: 1.722s
Oh, here s mine; completly dead on my end ! lol
○ scx.service - Start scx_scheduler
     Loaded: loaded (/usr/lib/systemd/system/scx.service; disabled; preset: disabled)
     Active: inactive (dead)
You can start your preferred shceduler as per wiki article. e.g. sudo scx_rusty
Thx, I ll check it out @indy
I ll have to kick my butt & figure that out. lol
Wow, looks great @indy , the price, less so ! lol
LAVD is doing wonders to my games! They are crazy smooth! I had high hope for scx_bpfland, but in the end I prefered scx_lavd.
❯ uname -a
Linux gaming 6.10.10-2-cachyos #1 SMP PREEMPT_DYNAMIC Fri, 13 Sep 2024 18:44:28 +0000 x86_64 GNU/Linux
# List of scx_schedulers: scx_bpfland scx_central scx_lavd scx_layered scx_nest scx_qmap scx_rlfifo scx_rustland scx_rusty scx_simple scx_userland
SCX_SCHEDULER=scx_lavd --performance --no-core-compaction
#SCX_SCHEDULER=scx_bpfland
I’ve noticed that when I set the flags I want using SCX_FLAGS, they won’t apply when SCX_SCHEDULER is set to scx_lavd. I’ve verified using htop.
I found that flags only apply when I set them on SCX_SCHEDULER like this:
I wonder if this behavior only apply to my installation.
Hey @iSpeakVeryWell , might be a simple oversight. Have you put the single quotation marks?
Finally got it to work @indy , but something s disabled ( Presets), anyways, forgot one command & to reboot afterward, it might be why I never got it to work;
     Active: active (running) since Sat 2024-09-14 12:29:23 EDT; 5min ago
 Invocation: 41484a76f89b47b792f29b553b349402
   Main PID: 623 (scx_bpfland)
      Tasks: 4 (limit: 18870)
     Memory: 18.3M (peak: 29.9M)
        CPU: 168ms
             └─623 scx_bpfland -s 20000 --lowlatency --primary-domain all
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] preferred CPU domain = 0x3f
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] primary CPU domain = 0x3f
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] cpufreq performance level: auto
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 1: sibling CPUs: [1]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 5: sibling CPUs: [5]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 4: sibling CPUs: [4]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 0: sibling CPUs: [0]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 2: sibling CPUs: [2]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L2 cache ID 3: sibling CPUs: [3]
Sep 14 12:29:23 cachyos-x8664 bash[623]: 16:29:23 [INFO] L3 cache ID 0: sibling CPUs: [0, 1, 2, 3, 4, 5]
Hard to say, it was a good while ago. I’ve just tried to reproduce the problem but wasn’t able to, which is a good news! Maybe a bug that have been fixed since then, or maybe I had messed up, it’s not impossible.
