Cachyos is not installing
Hi there.
Please can you help me. My online installer get stucked at initialize pacman… Ranking mirrors… Copy pacman mirrorlist and keyring to target…
Also the live USB doesn’t recognise the TouchPad so I have to left click instead. This is really annoying. I had high hopes for cachyos. I want to use it to replace my manjaro os. Any help will be appreciated thanks.
https://termbin.com/0k9s
This is my error log
==> Done [arch] /etc/pacman.d/mirrorlist
 --> name 'cachyos'; mirrorlist_path '/etc/pacman.d/cachyos-mirrorlist'; special_arch ''
# STARTED AT: 2024-06-11 16:49:48.732267810 +01:00
# ARGS: rate-mirrors --allow-root --save=/tmp/tmp.f8SE9VU4af cachyos --fetch-mirrors-timeout=300000
Error: failed to connect to https://raw.githubusercontent.com/CachyOS/CachyOS-PKGBUILDS/master/cachyos-mirrorlist/cachyos-mirrorlist, consider increasing fetch-mirrors-timeout
2024-06-11 - 16:54:48 [6]: virtual void Calamares::JobThread::run()
Somehow you can not connect to github in around 300 seconds. Can you maybe try to change your DNS Server?
Thank you for your prompt response. I also noticed that the packages section does not load and my TouchPad is not recognizable. Is there a workaround. I will change the dns server. Thanks once again. Looking forward to your response.
