CachyOS Installation Assistance
Hello there,
I have been attempting to install CachyOS for the past two days and I been getting multiple errors this is one of them.
https://termbin.com/d6nu
https://termbin.com/3895n - Second Attempt
Any assistance will be greatly appreciated!
Can only post two links;
https://termbin.com/fveg - Third Attempt - I think this one deals with Keyring, im attempt a sudo pacman-key --init, then --refresh-keys, then --populate archlinux cachyos
https://termbin.com/6sfu - Fourth Attempt - The keyring issue is fixed after doing the commands above, I just not sure why it keeps failing.
How are you installing CachyOS, i.e. what install options did you choose? Somehow it looks like all kernel modules are missing.
