Cachyos hangs when trying to boot from usb stick for install
Thanks!!! However, if there is an ISO somewhere in the github issue page, I did not find it.
Guess I’ll have to try to contain my eagerness and wait for your test ISO. :wink:
I’m sorry for the long delay, there’s testing ISO:
Greetings from CachyOS Live environment. New ISO worked super-duper. THANKS!!!
So now, the question is, should I go ahead and install or wait for a non-testing ISO version?
EDIT: Actually, that is not even the question right now. Very likely, trying to proceed with an install is going to get me to a thermal shutdown. Just idling here it’s at 84C:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +84.0°C  (high = +86.0°C, crit = +100.0°C)
I’ve tried to install acpi-call-dkms to be able to turn off my Nvidia card that’s very likely causing much of the overheating, but the install balks seemingly because of the kernel name:
$ sudo pacman -Sy acpi_call-dkms
 cachyos                               500.1 KiB   864 KiB/s 00:01 [------------------------------------] 100%
 core                                  120.1 KiB   409 KiB/s 00:00 [------------------------------------] 100%
 extra                                   7.8 MiB  2.54 MiB/s 00:03 [------------------------------------] 100%
 multilib                              131.9 KiB   349 KiB/s 00:00 [------------------------------------] 100%
resolving dependencies...
Package (12)          New Version                Net Change  Download Size
extra/clang           20.1.8-1                   210.15 MiB      45.09 MiB
extra/compiler-rt     20.1.8-1                    45.59 MiB       3.69 MiB
cachyos/dkms          3.2.1-2                      0.15 MiB       0.05 MiB
core/gc               8.2.8-2                      0.76 MiB       0.23 MiB
core/gcc              15.1.1+r7+gf36ec88aa85a-1  208.12 MiB      53.97 MiB
core/guile            3.0.10-1                    54.73 MiB       8.31 MiB
core/libisl           0.27-1                       5.75 MiB       0.87 MiB
extra/lld             20.1.8-1                     6.57 MiB       1.92 MiB
extra/llvm            20.1.8-1                   116.38 MiB      21.18 MiB
core/make             4.4.1-2                      1.67 MiB       0.51 MiB
core/patch            2.8-1                        0.17 MiB       0.08 MiB
extra/acpi_call-dkms  1.2.2-2                      0.03 MiB       0.01 MiB
Total Download Size:   135.91 MiB
Total Installed Size:  650.06 MiB
:: Retrieving packages...
 make-4.4.1-2-x86_64                   523.8 KiB   530 KiB/s 00:01 [------------------------------------] 100%
 patch-2.8-1-x86_64                     85.2 KiB  52.2 KiB/s 00:02 [------------------------------------] 100%
 dkms-3.2.1-2-any                       46.7 KiB  81.1 KiB/s 00:01 [------------------------------------] 100%
 libisl-0.27-1-x86_64                  886.4 KiB   422 KiB/s 00:02 [------------------------------------] 100%
 acpi_call-dkms-1.2.2-2-any             12.1 KiB  37.1 KiB/s 00:00 [------------------------------------] 100%
 gc-8.2.8-2-x86_64                     234.5 KiB   101 KiB/s 00:02 [------------------------------------] 100%
 lld-20.1.8-1-x86_64                  1966.7 KiB   489 KiB/s 00:04 [------------------------------------] 100%
 compiler-rt-20.1.8-1-x86_64             3.7 MiB   509 KiB/s 00:07 [------------------------------------] 100%
 guile-3.0.10-1-x86_64                   8.3 MiB   503 KiB/s 00:17 [------------------------------------] 100%
 gcc-15.1.1+r7+gf36ec88aa85a-1-x86_64   54.0 MiB  1885 KiB/s 00:29 [------------------------------------] 100%
 llvm-20.1.8-1-x86_64                   21.2 MiB   650 KiB/s 00:33 [------------------------------------] 100%
 clang-20.1.8-1-x86_64                  45.1 MiB  1080 KiB/s 00:43 [------------------------------------] 100%
 Total (12/12)                         135.9 MiB  3.18 MiB/s 00:43 [------------------------------------] 100%
error: failed retrieving file 'gcc-15.1.1+r7+gf36ec88aa85a-1-x86_64.pkg.tar.zst' from archlinux.cachyos.org : The requested URL returned error: 404
(12/12) checking keys in keyring                                   [------------------------------------] 100%
(12/12) checking package integrity                                 [------------------------------------] 100%
(12/12) loading package files                                      [------------------------------------] 100%
(12/12) checking for file conflicts                                [------------------------------------] 100%
:: Processing package changes...
( 1/12) installing libisl                                          [------------------------------------] 100%
( 2/12) installing gcc                                             [------------------------------------] 100%
Optional dependencies for gcc
    lib32-gcc-libs: for generating code for 32-bit ABI
( 3/12) installing compiler-rt                                     [------------------------------------] 100%
( 4/12) installing clang                                           [------------------------------------] 100%
Optional dependencies for clang
    openmp: OpenMP support in clang with -fopenmp
    python: for scan-view and git-clang-format [installed]
    llvm: referenced by some clang headers [pending]
( 5/12) installing lld                                             [------------------------------------] 100%
( 6/12) installing llvm                                            [------------------------------------] 100%
( 7/12) installing gc                                              [------------------------------------] 100%
( 8/12) installing guile                                           [------------------------------------] 100%
( 9/12) installing make                                            [------------------------------------] 100%
(10/12) installing patch                                           [------------------------------------] 100%
Optional dependencies for patch
    ed: for patch -e functionality
(11/12) installing dkms                                            [------------------------------------] 100%
Optional dependencies for dkms
    linux-headers: build modules against the Arch kernel
    linux-lts-headers: build modules against the LTS kernel
    linux-zen-headers: build modules against the ZEN kernel
    linux-hardened-headers: build modules against the HARDENED kernel
(12/12) installing acpi_call-dkms                                  [------------------------------------] 100%
:: Running post-transaction hooks...
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> ERROR: Missing etc kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing usr kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing lib64 kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing sys kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing dev kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing home kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing bin kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing boot kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing tmp kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing lib kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing version kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing run kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing var kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing root kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing mnt kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing opt kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing srv kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing proc kernel headers for module acpi_call/1.2.2.
==> ERROR: Missing sbin kernel headers for module acpi_call/1.2.2.
(3/3) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-cachyos.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-linux-cachyos -g /boot/initramfs-linux-cachyos.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-linux-cachyos'
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'archiso'
==> Using configuration file: '/etc/mkinitcpio.conf.d/archiso.conf'
  -> -k /boot/vmlinuz-linux-cachyos -c /etc/mkinitcpio.conf.d/archiso.conf -g /boot/initramfs-linux-cachyos.img
error: command failed to execute correctly
HELP!
So while I was waiting for any input, I figured I ought to try the “Legacy Graphics” boot option. Not good. Got farther than previous ISO but wound up stuck at a screen with (sorry, going from memory):
Finished Initializing Pacman Keyring
Reached Target Multi-User System
Reached Target Graphical Interface
Yeah, but no graphical interface launches. Dead in the water…
I think your best bet is to limit the CPU frequency. You can do that in Live ISO using this command for example:
echo "powersave" | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
Thanks, @ventureo , but how much does the live KDE/Wayland environment rely on the nouveau driver and Nvidia graphics? Just having the card ON spikes my temperatures. If it’s actually being used, I’m screwed. My mobo has no fan control, can’t be undervolted, and the fan itself is a pitiful piece of plastic ware, about as effective as the old hand fans in churches back in the day…
No doubt if I do try this, I’ll also have to turn off turbo.
