Suddenly the boot process stops - no error message
cursor keeps blinking but nothing goes on…
Until then the system started everytime
any ideas ?
@hotte that happened to me as well about a week ago, and simply shut the machine down (cold boot) and rebooted and things was fine.
I hope that works for you as well, never found any reason for the first frozen boot.
tried for three times before I wrote that message
always same behavior…
Yeah that was probably a given, trying multiple times.
I’m still trying to figure everyone’s skill set on Cachy Arch.
Any Snapshots, or back-up’s in place to revert to? I can’t see anything wrong in your screenshot.
Some tips I use, Check cables and connectors, re-plug the Drive again,
Is it after an update @hotte
Can you post the Bad Boot s Log @hotte , maybe the devs might check it out.
no log accessible
I gonna reinstall
Well that sux mate !
I would guess that you got to go trough TTY in order to fix your install @hotte
@ptr1337 @naim & other in the know members can help you out on that part @hotte
Well, sometimes it s the easiest/fastest way to fix it, I guess that I would ve have had some issues otherwise, but don t know how.
got it
guess it’s a problem of cosmic-DE
updated the init and the boot succeeded
