Hello, I’m having trouble with my audio devices when connecting with bluetooth; they connect but there’s no sound, then after a few seconds it disconnects. This happens on EOS as well: I’m new to this OS and Linux as a whole so I don’t know how I can troubleshoot, but I can follow instructions.
Hi, I’ve tried this and it worked at first, but after reboot it’s broken again.
Here is the error in the journalctl log: This happens every connection:
Blockquote
Feb 04 20:03:13 TianXuan5Pro bluetoothd[943]: src/device.c:device_new() Unable to register device interface for 00:00:00:00:00:00
Feb 04 20:03:13 TianXuan5Pro bluetoothd[943]: Unable to create object for found device 00:00:00:00:00:00
Feb 04 20:04:13 TianXuan5Pro bluetoothd[943]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
Feb 04 20:04:16 TianXuan5Pro bluetoothd[943]: src/device.c:device_new() Unable to register device interface for 00:00:00:00:00:00
Feb 04 20:04:16 TianXuan5Pro bluetoothd[943]: Unable to create object for found device 00:00:00:00:00:00
Feb 04 20:04:30 TianXuan5Pro bluetoothd[943]: profiles/audio/avdtp.c:cancel_request() Start: Connection timed out (110)
Feb 04 20:04:32 TianXuan5Pro bluetoothd[943]: profiles/audio/avdtp.c:cancel_request() Abort: Connection timed out (110)
Feb 04 20:04:49 TianXuan5Pro bluetoothd[943]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 04 20:06:18 TianXuan5Pro bluetoothd[943]: /org/bluez/hci0/dev_41_42_1A_4B_8A_7F/sep2/fd1: fd(31) ready
Feb 04 20:06:50 TianXuan5Pro bluetoothd[943]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 04 20:12:07 TianXuan5Pro bluetoothd[943]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 41:42:1A:4B:8A:7F: Device or resource busy
Feb 04 20:12:12 TianXuan5Pro bluetoothd[943]: profiles/audio/avdtp.c:cancel_request() Discover: Connection timed out (110)
Feb 04 20:12:35 TianXuan5Pro bluetoothd[943]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 04 20:12:45 TianXuan5Pro bluetoothd[943]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 41:42:1A:4B:8A:7F: Device or resource busy
Another thing is that the earbuds worked before on EOS but then stopped working, and it persisted to Cachy. However I’ve just bought a headphone and its bluetooth is also currently working fine. I dont know what to make of this trend.
Ok, headphones have been working splendidly for the past few days between both OSes. So I think it might be a hardware issue. Searches suggest it is a driver issue, but I’m not sure how to find out the specific problem: at the very least it is related to how the earbuds connect. (Defunc True Basic)
I don’t know the technical details but are there different methods of bluetooth connection?
