Better multi-monitor support
Every time there is a different configuration of displays, like If I plug or more or turn certain combinations on, it seems to reset any sort of configuration done to it.
I dont think this problem are specific to CachyOS, but it would be nice to have a tool that are smarter in handling these things, added in.
Another scenario that can reset, is if I enable something like the experimental VRR, it’s like a whole another profile that can reset current configurations.
Profiles should be done per monitor, not based on the current combination. Ideally would be for them to start working together if another are turned on or plugged in. Each retaining their configuration. Maybe that would solve the problem.
