Im new to Cahy. I have installed Cachyos on my Legion Go. When installing i set it to autologin but im gretted with a login screen on every boot. Bad thing is onscreen keyboard wont work so i have to go hookup to a keyboard to get this thing going and that isnt really an option. Any help is appreciated. Thanks
using what DE?
KDE maybe? Its for the handheld edition. Ive learned that screen is for drive encryption and i need to disable that. Is there a way other than a full new install to do that?
in most case a new install would be a very good solution
I was afraid of that. I had installed a couple big games and i use starlink so that takes a while to redo lol
KDE doesn’t have anything to do with drive encryption.
I don’t use drive encryption but IIRC that is handled by plymouth
? I have no idea.
If it does not ask for a user name it is not a login screen but some kind of device/drive lock.
Yeah thats pretty much what i gathered. I just reinstalled from scratch. Thanks though.
Is the outcome now different? What have you changed?
I guess just disabled encryption (or actually not enabling it during partition section in installer) would remove rhat unlock screen. Just like in any other installation.
