Audiotube fails to start
Hey guys,
I’ve installed audiotube from the cachyos-extra-v3 repo and it fails to start.
❯ audiotube
futuresql: Running migration "2022-05-20-194850_init"
futuresql: Running "-- SPDX-FileCopyrightText: 2022 Jonah Brüchert <jbb@kaidan.im>\n--\n-- SPDX-License-Identifier: GPL-2.0-only OR GPL-3.0-only OR LicenseRef-KDE-Accepted-GPL\n\ncreate table songs (\n    video_id Text primary key not null,\n    title Text not null,\n    artist Text,\n    album Text\n)"
futuresql: Running "create table played_songs (\n    video_id Text primary key not null,\n    plays Int not null,\n    foreign key (video_id) references songs(video_id)\n)"
futuresql: Running "create table favourites (\n    video_id Text primary key not null,\n    foreign key (video_id) references songs(video_id)\n)"
futuresql: Running "create table searches (\n    search_id integer primary key autoincrement not null,\n    search_query Text not null\n)"
futuresql: Marking migration "2022-05-20-194850_init" as done.
futuresql: Running migration "2022-05-25-212054_playlists"
futuresql: Running "-- SPDX-FileCopyrightText: 2022 Jonah Brüchert <jbb@kaidan.im>\n--\n-- SPDX-License-Identifier: GPL-2.0-only OR GPL-3.0-only OR LicenseRef-KDE-Accepted-GPL\n\ncreate table playlists (\n    playlist_id Integer primary key autoincrement not null,\n    title Text not null,\n    description Text,\n    created_on Timestamp not null default current_timestamp\n)"
futuresql: Running "create table playlist_entries (\n    playlist_id Integer not null,\n    video_id Text not null,\n    primary key (playlist_id, video_id)\n    foreign key (video_id) references songs(video_id),\n    foreign key (playlist_id) references playlists(playlist_id)\n)"
futuresql: Marking migration "2022-05-25-212054_playlists" as done.
futuresql: Migrations finished
futuresql: Running "select distinct (search_query) from searches order by search_id desc limit 20"
futuresql: Running "select * from favourites natural join songs order by favourites.rowid desc"
futuresql: Running "select * from played_songs natural join songs"
futuresql: Running "select * from played_songs natural join songs order by plays desc limit 10"
Running with untested version of ytmusicapi 1.8.1.
The currently tested and supported version is 1.8.0
futuresql: Running "select * from playlists"
qrc:/AlbumCoverItem.qml:19:12: Duplicate signal name: invalid override of property change signal or superclass signal
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:358:9
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:344:18: QML ScrollView: Binding loop detected for property "calculatedImplicitHeight":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:361:9
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:401:33: QML Binding: Binding loop detected for property "value":
qrc:/qt/qml/org/kde/kirigami/dialogs/Dialog.qml:409:13
qt.qml.list.incompatible: Cannot append QQuickRepeater(0x64cbfea0b7c0) to a QML list of QQuickAbstractButton*
Executando uma versão não testada do ytmusicapi 1.8.1. Se você tiver erros, comunique-os à sua distribuição.
Failed to initialize QAudioOutput "Could not find the autoaudiosink GStreamer element"
fish: Tarefa 1, 'audiotube' encerrada pelo sinal SIGSEGV (Erro de fronteira de endereço (Falha de segmentação))
Perhaps it is missing a gstreamer-related dependency? I am running KDE Plasma, default installation, up to date.
Same problem for me, were you able to solve it?
edit:
i have just installed these packages and it works for me
pacman -S gstreamer gst-plugins-base gst-plugins-good gst-plugins-bad gst-plugins-ugly
