Hello there
I have installed CachyOS using KDE and Wayland since about 3 weeks by now and unfortunately, I’m not able to completely fix the problem I’m facing. Basically, my audio cuts out. I’m using an HDMI cable coming from my Nvidia graphics card (RTX 3080) which is connected to my Denon AVR / surround system.
When I’m not using my computer, let’s say, I simply watch a Youtube video, the problem happens seldom but still can occasionally occur. If I start using my computer beside watching, such as opening/clsoing a new browser window, generally open/close apps, it keeps cutting out, maybe like every minute or so but of course, this is very random.
My system is up-to-date as of right now. I can also confirm that it’s not a hardware/cable issue because in Windows, there are no cut outs no matter what I do.
I want to mention what I have changed since I have installed CachyOS because that might be relevant. Other than that, everything is default:
I have installed the following according to the CachyOS wiki which made things a little better but didn’t fix the problem really:
sudo pacman -S realtime-privileges
sudo gpasswd -a $USER realtime
I have installed the following package since it seems that this is needed when having a webcam. However, I doubt this is relevant here really:
sudo pacman -S pipewire-libcamera
Regarding configurations:
In pavucontrol → “Output Devices”, I have set the “Port” for my “GA102 High Defintion Audio Controller Digital Surround 5.1 (HDMI)” to “HDMI / DisplayPort (plugged in)” and set it as default. In the “Configuration” tab, I have set the “Profile” to “Digital Surround 5.1 (HDMI Output)”.
Also, I have enabled all the codecs under “Advance”.
Bug report can be accessed here:
In case you need more information, feel free to ask. Thanks for your time in advance.
